Remove-SmStorageConnection
Removes a storage system connection.
Syntax
Remove-SmStorageConnection [-Storage] <String> [-AzureNetAppAccountIds] <bigint(20)>
Detailed Description
Removes a storage system connection. You can remove one storage system connection at a time.
Name | Description | Required? | Pipeline Input | Default Value |
Storage |
false |
true (ByPropertyName) |
Example 1: Removing a storage system connection
Remove-SmStorageConnection -SVM 172.17.168.13
This example syntax removes a storage system connection
Are you sure you want to remove the storage connection?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Remove Storage connection successful
Example 2: Removing a storage system connection without confirmation dialogue
Remove-SmStorageConnection -SVM 172.17.168.13 -Confirm:$false
Example 3: Removing Azure NetApp Account
Remove-SmStorageconnection -AzureNetAppAccountIds 1
This example removes Azure NetApp Accounts with specified Azure NetApp Account IDs.
