SnapCenter cmdlets
Set-SmESXInfo
Updates the parent ESX information for SQL hosts.
Syntax
Set-SmESXInfo [-HostName]  <String>
Detailed Description
Updates the parent ESX information for SQL hosts. The host must be of SQL type.
Name Description Required? Pipeline Input Default Value
HostName
The name of the SQL host.
true
true (ByPropertyName)
Example 1: Updating the parent ESX information for an SQL host
 Set-SmESXInfo -HostName csmdev-smsql-02.sddev.mycompany.com -Verbose
This example syntax updates the parent ESX information for the specified SQL host.
VERBOSE: Start Set-SmESXInfo
ESX information updated successfully
VERBOSE: Set-SmESXInfo ended successfully.
