Set-SmESXInfo
Updates the parent ESX information for SQL hosts.
Syntax
Set-SmESXInfo [-HostName] <String>
Detailed Description
Updates the parent ESX information for SQL hosts. The host must be of SQL type.
Name | Description | Required? | Pipeline Input | Default Value |
HostName |
The name of the SQL host. |
true |
true (ByPropertyName) |
Example 1: Updating the parent ESX information for an SQL host
Set-SmESXInfo -HostName csmdev-smsql-02.sddev.mycompany.com -Verbose
This example syntax updates the parent ESX information for the specified SQL host.
VERBOSE: Start Set-SmESXInfo
ESX information updated successfully
VERBOSE: Set-SmESXInfo ended successfully.
