SnapCenter 4.7 cmdlets
Set-SmCertificateSettings
Enables you to modify the certificate settings for the SnapCenter Server host or a SnapCenter plug-in host.
Syntax
Set-SmCertificateSettings [-Server]  <>  [-Enable]  <>  [-Disable]  <>  [-Host]  <>  [-HostName]  <String>  [-Enable]  <>  [-Disable]  <>
Detailed Description
Name Description Required? Pipeline Input Default Value
Server
Enables the Snapcenter server to perform SSL Secure validations.
true
false
Host
Specifies that you want to perform SSL Secure validations on Snapcenter Host.
true
false
HostName
Specifies the name of the host on which you want to perform SSL Secure validations.
true
false
Enable
Specifies the Snapcenter server or host to enable SSL Secure validations.
true
false
Disable
Specifies the Snapcenter server or host to disable SSL Secure validations.
true
false
Example 1: Updating certificate settings for server
 Set-SmCertificateSettings -Server -Enable
This example syntax sets certificate settings for server. Enables the server to perform SSL secure validations.
Name: Enabling certificate validation on server
			StartTime   : 3/12/2021 1:42:58 PM
			EndTime : 3/12/2021 1:42:59 PM
			IsCancellable   : False
			IsRestartable   : False
			IsCompleted : False
			IsVisible   : True
			IsScheduled : False
			PercentageCompleted : 100
			Description :
			Status  : Completed
			Owner   :
			Error   :
			Priority: None
			Tasks   : {}
			ParentJobID : 0
			EventId : 0
			JobTypeId   : 38
			ApisJobKey  :
			ObjectId: 0
			PluginCode  : NONE
			PluginName  : NONE
			HostId  : 0
			RoleId  :
			JobIds  : {}
Example 2: Updating certificate settings for Host
 Set-SmCertificateSettings -Host -HostName R71104B320CV1.mva.gdl.englab.netapp.com -Enable
This example syntax sets certificate settings for host. Enables the host to perform SSL secure validations.
Name: Enabling certificate validation on Host R71104B320CV1.mva.gdl.englab.netapp.com
			StartTime   : 3/12/2021 1:47:06 PM
			EndTime : 3/12/2021 1:47:13 PM
			IsCompleted : False
			IsVisible   : True
			IsScheduled : False
			Description :
			Status  : Completed
			Owner   :
			Error   :
			Priority: None
			Tasks   : {}
			ParentJobID : 0
			EventId : 0
			JobTypeId   : 38
			ApisJobKey  :
			ObjectId: 0
			PluginCode  : NONE
			PluginName  : NONE
			HostId  : 0
			RoleId  :
			JobIds  : {}
