Set-SmCertificateSettings
Enables you to modify the certificate settings for the SnapCenter Server host or a SnapCenter plug-in host.
Syntax
Set-SmCertificateSettings [-Server] <> [-Enable] <> [-Disable] <> [-Host] <> [-HostName] <String> [-Enable] <> [-Disable] <>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Server |
Enables the Snapcenter server to perform SSL Secure validations. |
true |
false |
Host |
Specifies that you want to perform SSL Secure validations on Snapcenter Host. |
true |
false |
HostName |
Specifies the name of the host on which you want to perform SSL Secure validations. |
true |
false |
Enable |
Specifies the Snapcenter server or host to enable SSL Secure validations. |
true |
false |
Disable |
Specifies the Snapcenter server or host to disable SSL Secure validations. |
true |
false |
Example 1: Updating certificate settings for server
Set-SmCertificateSettings -Server -Enable
This example syntax sets certificate settings for server. Enables the server to perform SSL secure validations.
Name: Enabling certificate validation on server
StartTime : 3/12/2021 1:42:58 PM
EndTime : 3/12/2021 1:42:59 PM
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : True
IsScheduled : False
PercentageCompleted : 100
Description :
Status : Completed
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 38
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName : NONE
HostId : 0
RoleId :
JobIds : {}
Example 2: Updating certificate settings for Host
Set-SmCertificateSettings -Host -HostName R71104B320CV1.mva.gdl.englab.netapp.com -Enable
This example syntax sets certificate settings for host. Enables the host to perform SSL secure validations.
Name: Enabling certificate validation on Host R71104B320CV1.mva.gdl.englab.netapp.com
StartTime : 3/12/2021 1:47:06 PM
EndTime : 3/12/2021 1:47:13 PM
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Completed
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 38
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName : NONE
HostId : 0
RoleId :
JobIds : {}
