SnapCenter 4.7 cmdlets
Remove-SmPolicy
Removes one or more policies from SnapCenter.
Syntax
Remove-SmPolicy [-PolicyNames]  <String>
Detailed Description
Removes one or more policies from SnapCenter. In order to delete polices from SnapCenter, you must have already detached them from any datasets with which they are associated.
Name Description Required? Pipeline Input Default Value
PolicyNames
Identifies the policy you want to delete. You can provide an individual policy name or a comma-separated list.
true
true (ByPropertyName)
Example 1: Deleting a policy from SnapCenter
 Remove-SmPolicy -PolicyNames ‘SQL Full Backup’
This example syntax removes a specified policy.
Remove-SmPolicy
Are you sure you want to remove the dataset policy. Its association with dataset also gets removed.?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):
Example 1: Deleting a policy from SnapCenter without confirmation dialogue
 Remove-SmPolicy -PolicyNames ‘SQL Full Backup’ -Confirm:$false
