Remove-SmPolicy
Removes one or more policies from SnapCenter.
Syntax
Remove-SmPolicy [-PolicyNames] <String>
Detailed Description
Removes one or more policies from SnapCenter. In order to delete polices from SnapCenter, you must have already detached them from any datasets with which they are associated.
| Name | Description | Required? | Pipeline Input | Default Value |
PolicyNames |
Identifies the policy you want to delete. You can provide an individual policy name or a comma-separated list. |
true |
true (ByPropertyName) |
Example 1: Deleting a policy from SnapCenter
Remove-SmPolicy -PolicyNames ‘SQL Full Backup’
This example syntax removes a specified policy.
Remove-SmPolicy
Are you sure you want to remove the dataset policy. Its association with dataset also gets removed.?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):
Example 1: Deleting a policy from SnapCenter without confirmation dialogue
Remove-SmPolicy -PolicyNames ‘SQL Full Backup’ -Confirm:$false
