Set-SmServerConfig
Updates the High Availability cluster configuration on the SnapCenter Server and all the plug-in hosts.
Syntax
Set-SmServerConfig [-Credential] <PSCredential> [-UpdateSMSbaseUrlSwitchParameter] <SwitchParameter> [-HostNamesString] <String> [-OverwriteSmsUrlString] <String>
Detailed Description
Updates High Availability cluster configuration on the plug-in hosts. If no hostnames are specified, it will be updated to all the registered hosts.
| Name | Description | Required? | Pipeline Input | Default Value |
Credential |
Provides domain user credentials for the user to update High Availability cluster configuration. |
true |
true (ByPropertyName) |
UpdateSMSbaseUrl |
Update SnapCenter Server URL. |
true |
false |
HostNames |
Comma separated host names. |
false |
false |
OverwriteSmsUrl |
Overwrites the SMSBaseURL. |
false |
false |
Example 1: Updating High Availability cluster configuration on the SnapCenter Server
Set-SmServerConfig -Credential sddev\administrator -UpdateSMSbaseUrl
This example updates the High Availability cluster configuration on all the plug-in hosts and on the SnapCenter Server.
Name: Configuring for SnapCenter Server URL
StartTime : 9/3/2019 5:25:10 AM
EndTime :
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status : Running
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 38
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName : NONE
HostId : 0
RoleId :
JobIds : {}
Example 2: Updating High Availability cluster configuration on the specific hosts
Set-SmServerConfig -UpdateSMSbaseUrl -HostNames 10.225.13.94,10.225.13.96
This example updates the High Availability cluster configuration on the specified hosts.
EndTime :
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Running
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 38
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName : NONE
HostId : 0
RoleId :
JobIds : {}
