SnapCenter 4.8 cmdlets
Set-SmServerConfig
Updates the High Availability cluster configuration on the SnapCenter Server and all the plug-in hosts.
Syntax
Set-SmServerConfig [-Credential]  <PSCredential>  [-UpdateSMSbaseUrlSwitchParameter]  <SwitchParameter>  [-HostNamesString]  <String>  [-OverwriteSmsUrlString]  <String>
Detailed Description
Updates High Availability cluster configuration on the plug-in hosts. If no hostnames are specified, it will be updated to all the registered hosts.
Name Description Required? Pipeline Input Default Value
Credential
Provides domain user credentials for the user to update High Availability cluster configuration.
true
true (ByPropertyName)
UpdateSMSbaseUrl
Update SnapCenter Server URL.
true
false
HostNames
Comma separated host names.
false
false
OverwriteSmsUrl
Overwrites the SMSBaseURL.
false
false
Example 1: Updating High Availability cluster configuration on the SnapCenter Server
 Set-SmServerConfig -Credential sddev\administrator -UpdateSMSbaseUrl
This example updates the High Availability cluster configuration on all the plug-in hosts and on the SnapCenter Server.
Name: Configuring for SnapCenter Server URL
StartTime   : 9/3/2019 5:25:10 AM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 38
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
Example 2: Updating High Availability cluster configuration on the specific hosts
 Set-SmServerConfig -UpdateSMSbaseUrl -HostNames 10.225.13.94,10.225.13.96
This example updates the High Availability cluster configuration on the specified hosts.
EndTime :
IsCompleted : False
IsVisible   : True
IsScheduled : False
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 38
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
