Set-SmAuditSettings
Set the audit file retention, size and location.
Syntax
Set-SmAuditSettings [-MaxFileSize] <String> [-MaxSizeRollBackups] <EntityType> [-AuditLogDirectory] <String> [-UniversalTime] <Severity>
Detailed Description
Sets the audit file maximum size, the maximum number of audit file backups to retain, and location for audit file.
| Name | Description | Required? | Pipeline Input | Default Value |
MaxFileSize |
The audit file size that triggers a roll over. |
true |
false |
MaxSizeRollBackups |
The number of roll over audit files that are retained. |
true |
false |
AuditLogDirectory |
The location where audit files are generated. |
true |
false |
UniversalTime |
Enables message logging in UTC time for installations in different geographical locations. Use $True to enable UniversalTime or $False to disable UniversalTime. |
false |
false |
Example 1: Setting audit log settings
Set-SmAuditSettings -MaxFileSize 10MB -MaxSizeRollBackups 10 -AuditLogDirectory C:\auditing\
This example sets audit log settings.
MaxFileSize MaxSizeRollBackups UniversalTime LogDirectory
10485760 10 False C:\auditing\
