SnapCenter 4.7 cmdlets
Get-SmAssignedRoles
Gets the roles assigned to a specified user or Active Directory group.
Syntax
Get-SmAssignedRoles [-UserName]  <String>  [-UserGroupObjectType]  <SmUserGroupObjectType>
Detailed Description
Name Description Required? Pipeline Input Default Value
UserName
Specifies the domain\username for the user about which you want to get role information.
true
true (ByPropertyName)
UserGroupObjectType
Specifies that the domain\username for which you are requesting role information is a group.
false
Example 1: Getting roles for a particular user
 Get-SmAssignedRoles -UserName sddev\administrator
This example syntax gets the roles assigned to a user.
Description : Overall administrator of SnapCenter system
Type: Administrator
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
Example 2: Getting roles assigned to a group
 Get-SmAssignedRoles -UserName sddev\b-grp -UserGroupObjectType Group
Description :
Type:
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Hosts   : {}
