Get-SmAssignedRoles
Gets the roles assigned to a specified user or Active Directory group.
Syntax
Get-SmAssignedRoles [-UserName] <String> [-UserGroupObjectType] <SmUserGroupObjectType>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
UserName |
Specifies the domain\username for the user about which you want to get role information. |
true |
true (ByPropertyName) |
UserGroupObjectType |
Specifies that the domain\username for which you are requesting role information is a group. |
false |
Example 1: Getting roles for a particular user
Get-SmAssignedRoles -UserName sddev\administrator
This example syntax gets the roles assigned to a user.
Description : Overall administrator of SnapCenter system Name: SnapCenterAdmin Type: Administrator Id : 1 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0
Example 2: Getting roles assigned to a group
Get-SmAssignedRoles -UserName sddev\b-grp -UserGroupObjectType Group
Description : Name: role1 Type: Id : 20 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Hosts : {}
