SnapCenter 4.7 cmdlets
Remove-SmRole
Removes an RBAC role.
Syntax
Remove-SmRole [-Name]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Name
Names the RBAC role you want to delete.
true
true (ByPropertyName)
Example 1: Removing a specific role
 Remove-SmRole -Name BackupAdmin
This example syntax removes the specified role from SnapCenter.
Remove-SmRole
Are you sure you want to remove the role ?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Example 2: Removing a specific role without confirmation dialogue
 Remove-SmRole -Name BackupAdmin -Confirm:$false
