Remove-SmRole
Removes an RBAC role.
Syntax
Remove-SmRole [-Name] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Name |
Names the RBAC role you want to delete. |
true |
true (ByPropertyName) |
Example 1: Removing a specific role
Remove-SmRole -Name BackupAdmin
This example syntax removes the specified role from SnapCenter.
Remove-SmRole
Are you sure you want to remove the role ?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Example 2: Removing a specific role without confirmation dialogue
Remove-SmRole -Name BackupAdmin -Confirm:$false
