SnapCenter 4.7 cmdlets
Set-SmDisasterRecovery
Enables storage disaster recovery.
Syntax
Set-SmDisasterRecovery [-Enable]  <>  [-Disable]  <>
Detailed Description
Enables or disables storage disaster recovery.
Name Description Required? Pipeline Input Default Value
Enable
Specifies the SnapCenter Server to enable storage disaster recovery.
true
false
Disable
Specifies the SnapCenter Server to disable storage disaster recovery.
true
false
Example 1: Enabling storage disaster recovery
 Set-SmDisasterRecovery -Enable
This example syntax enables storage disaster recovery.
Before enabling this option, make sure all the SCSQL resources are online and active on the secondary storage.Are you sure you want to enable disaster recovery??
[Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "Y"):
Name:
StartTime   :
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   :
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  :
HostId  : 0
RoleId  :
JobIds  :
 ErrorRecords : {}
_message :
_errorCode   : 0
Example 2: Disabling storage disaster recovery
 Set-SmDisasterRecovery -Disable
This example syntax disables storage disaster recovery.
Name:
			StartTime   :
			EndTime :
			IsCompleted : False
			IsVisible   : True
			IsScheduled : False
			Description :
			Status  : Running
			Owner   :
			Error   :
			Priority: None
			Tasks   : {}
			ParentJobID : 0
			EventId : 0
			JobTypeId   :
			ApisJobKey  :
			ObjectId: 0
			PluginCode  : NONE
			PluginName  :
			HostId  : 0
			RoleId  :
			JobIds  :
			ErrorRecords : {}
			_message :
			_errorCode   : 0
