Set-SmDisasterRecovery
Enables storage disaster recovery.
Syntax
Set-SmDisasterRecovery [-Enable] <> [-Disable] <>
Detailed Description
Enables or disables storage disaster recovery.
| Name | Description | Required? | Pipeline Input | Default Value |
Enable |
Specifies the SnapCenter Server to enable storage disaster recovery. |
true |
false |
Disable |
Specifies the SnapCenter Server to disable storage disaster recovery. |
true |
false |
Example 1: Enabling storage disaster recovery
Set-SmDisasterRecovery -Enable
This example syntax enables storage disaster recovery.
Before enabling this option, make sure all the SCSQL resources are online and active on the secondary storage.Are you sure you want to enable disaster recovery??
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):
Name:
StartTime :
EndTime :
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status : Running
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId :
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName :
HostId : 0
RoleId :
JobIds :
ErrorRecords : {}
_message :
_errorCode : 0
Example 2: Disabling storage disaster recovery
Set-SmDisasterRecovery -Disable
This example syntax disables storage disaster recovery.
Name:
StartTime :
EndTime :
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Running
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId :
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName :
HostId : 0
RoleId :
JobIds :
ErrorRecords : {}
_message :
_errorCode : 0
