Remove-SmCredential
Unregister a registered credential.
Syntax
Remove-SmCredential [-Name] <String>
Detailed Description
Remove a registered credential from the SnapCenter Server.
Name | Description | Required? | Pipeline Input | Default Value |
Name |
true |
true (ByPropertyName) |
Example 1: Remove Credential
Remove-SmCredential -Name RunAs1
