SnapCenter cmdlets
Remove-SmCredential
Unregister a registered credential.
Syntax
Remove-SmCredential [-Name]  <String>
Detailed Description
Remove a registered credential from the SnapCenter Server.
Name Description Required? Pipeline Input Default Value
Name
true
true (ByPropertyName)
Example 1: Remove Credential
 Remove-SmCredential -Name RunAs1
