Get-SmPluginConfiguration
Gets the plug-in configuration for a host.
Syntax
Get-SmPluginConfiguration [-PluginCode] <PluginCode> [-HostName] <String>
Detailed Description
Gets the plug-in information for a host.
| Name | Description | Required? | Pipeline Input | Default Value |
PluginCode |
The plug-in code. Valid values are SCW, SCSQL, and SCO. |
true |
true (ByPropertyName) |
HostName |
The name of the host on which the plug-in is installed. |
true |
Example 1: Getting plugin configuration information for a host
Get-SmPluginConfiguration -PluginCode SCSQL -HostName localhost
This example syntax gets the SnapCenter plug-in configuration for the specified host.
PluginInfoId :
HostName :
PluginName: SnapCenter Plug-in for Microsoft SQL Server
PluginVersion :
InstallPath :
Description :
VendorName:
EndpointURI : http://localhost:809/SqlManagementService
DateCreated :
DateModified :
Message :
Resources : {}
PluginCode: SMSQL
PluginConfiguration : SMCoreContracts.SmSqlConfiguration
ServiceName :
DisplayName :
ServiceStatus : Unavailable
PluginServiceAction : None
Port : 0
GUID :
PluginCompatibilityStatus : None
LicenseType : None
LicenseKey:
PluginInstallStatus : ePluginInstallStatusUnknown
HostMaintenanceStatus : Production
TCPPort : 0
Auth : SMCoreContracts.SmAuth
