SnapCenter 4.8 cmdlets
Get-SmPluginConfiguration
Gets the plug-in configuration for a host.
Syntax
Get-SmPluginConfiguration [-PluginCode]  <PluginCode>  [-HostName]  <String>
Detailed Description
Gets the plug-in information for a host.
Name Description Required? Pipeline Input Default Value
PluginCode
The plug-in code. Valid values are SCW, SCSQL, and SCO.
true
true (ByPropertyName)
HostName
The name of the host on which the plug-in is installed.
true
Example 1: Getting plugin configuration information for a host
 Get-SmPluginConfiguration -PluginCode SCSQL -HostName localhost
This example syntax gets the SnapCenter plug-in configuration for the specified host.
PluginInfoId  :
HostName  :
PluginName: SnapCenter Plug-in  for Microsoft SQL Server
PluginVersion :
InstallPath   :
Description   :
VendorName:
EndpointURI   : http://localhost:809/SqlManagementService
DateCreated   :
DateModified  :
Message   :
Resources : {}
PluginCode: SMSQL
PluginConfiguration   : SMCoreContracts.SmSqlConfiguration
ServiceName   :
DisplayName   :
ServiceStatus : Unavailable
PluginServiceAction   : None
Port  : 0
GUID  :
PluginCompatibilityStatus : None
LicenseType   : None
LicenseKey:
PluginInstallStatus   : ePluginInstallStatusUnknown
HostMaintenanceStatus : Production
TCPPort   : 0
Auth  : SMCoreContracts.SmAuth
