Get-SmAssignedGroups
Gets a list off all groups assigned to a role.
Syntax
Get-SmAssignedGroups [-RoleName] <String>
Detailed Description
Gets a list off all groups assigned to a user.
| Name | Description | Required? | Pipeline Input | Default Value |
RoleName |
Specifies the name of the role for which you want to find the assigned groups. |
true |
true (ByPropertyName) |
Example 1: Getting groups assigned to a particular role
Get-SmAssignedGroups -RoleName SnapcenterAdmin
The example syntax gets the groups assigned to the SnapCenterAdmin role.
Token :
TokenHashed : {}
TokenTime : 8/3/2015 5:07:50 PM
FullName:
Author :
Domain : sddev
Description :
TokenNeverExpires : False
IsAdmin : False
TenantAdmin :
IsNewUser :
UserGroupObjectType : Group
RoleName:
RoleId : 0
Type:
Host:
UserName:
Passphrase :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel : 0
