SnapCenter cmdlets
Get-SmAssignedGroups
Gets a list off all groups assigned to a role.
Syntax
Get-SmAssignedGroups [-RoleName]  <String>
Detailed Description
Gets a list off all groups assigned to a user.
Name Description Required? Pipeline Input Default Value
RoleName
Specifies the name of the role for which you want to find the assigned groups.
true
true (ByPropertyName)
Example 1: Getting groups assigned to a particular role
 Get-SmAssignedGroups -RoleName SnapcenterAdmin
The example syntax gets the groups assigned to the SnapCenterAdmin role.
Token   :
TokenHashed : {}
TokenTime   : 8/3/2015 5:07:50 PM
FullName:
Author  :
Domain  : sddev
Description :
TokenNeverExpires   : False
IsAdmin : False
TenantAdmin :
IsNewUser   :
UserGroupObjectType : Group
RoleName:
RoleId  : 0
Type:
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
