Get-SmAssignedGroups
Gets a list off all groups assigned to a role.
Syntax
Get-SmAssignedGroups [-RoleName] <String>
Detailed Description
Gets a list off all groups assigned to a user.
Name | Description | Required? | Pipeline Input | Default Value |
RoleName |
Specifies the name of the role for which you want to find the assigned groups. |
true |
true (ByPropertyName) |
Example 1: Getting groups assigned to a particular role
Get-SmAssignedGroups -RoleName SnapcenterAdmin
The example syntax gets the groups assigned to the SnapCenterAdmin role.
Token : TokenHashed : {} TokenTime : 8/3/2015 5:07:50 PM FullName: Author : Domain : sddev Description : TokenNeverExpires : False IsAdmin : False TenantAdmin : IsNewUser : UserGroupObjectType : Group RoleName: RoleId : 0 Name: administrators Type: Id : 3 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0
