Add-SdPortSetPort
Adds a port to an existing portset.
Syntax
Add-SdPortSetPort [-PortSetName] <String> [-Port] <String> [-StorageSystem] <String> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
PortSetName |
Specifies the name of the portset to which you want to add a new port. |
true |
true (ByPropertyName) |
Port |
Specifies the name of the port you want to add to your portset. |
true |
StorageSystem |
Specifies the storage system on which your portset resides. |
true |
Session |
Specifies the session ID from Open-SmConnection. For internal use only. |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
