SnapCenter 4.9 cmdlets
Add-SdPortSetPort
Adds a port to an existing portset.
Syntax
Add-SdPortSetPort [-PortSetName]  <String>  [-Port]  <String>  [-StorageSystem]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
PortSetName
Specifies the name of the portset to which you want to add a new port.
true
true (ByPropertyName)
Port
Specifies the name of the port you want to add to your portset.
true
StorageSystem
Specifies the storage system on which your portset resides.
true
Session
Specifies the session ID from Open-SmConnection. For internal use only.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
