      Add-SdPortSetPort
Adds a port to an existing portset.
Syntax
Add-SdPortSetPort [-PortSetName] <String> [-Port] <String> [-StorageSystem] <String> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
| PortSetName | Specifies the name of the portset to which you want to add a new port. | true | true (ByPropertyName) | |
| Port | Specifies the name of the port you want to add to your portset. | true | true (ByPropertyName) | |
| StorageSystem | Specifies the storage system on which your portset resides. | true | true (ByPropertyName) | |
| Session | Specifies the session ID from Open-SmConnection. For internal use only. | false | true (ByPropertyName) | |
| Host | Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. | false | true (ByPropertyName) |
 PDFs
PDFs
