Remove-SmUserFromRole
Deletes a user from an RBAC role.
Syntax
Remove-SmUserFromRole [-UserName] <SmString> [-RoleName] <String> [-Domain] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
UserName |
Specifies the user you want to remove from the RBAC role. |
true |
true (ByPropertyName) |
RoleName |
Specifies the name of the role from which you want to remove the user. |
true |
Domain |
Domain to which user belongs to. Workgroup users should skip this parameter. |
false |
Example 1: Deleting a role from a specific user
Remove-SmUserFromRole -UserName administrator -Domain mva -RoleName BackupAdmin
This example syntax removes the specified user from a role.
Are you sure you want to unassign the user from role?.
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
BackupAdmin
mva\administrator
Example 2: Deleting a role from a specific user without confirmation dialogue
Remove-SmUserFromRole -UserName administrator -Domain mva -RoleName BackupAdmin -Confirm:$false
BackupAdmin
mva\administrator
