SnapCenter 4.8 cmdlets
Remove-SmUserFromRole
Deletes a user from an RBAC role.
Syntax
Remove-SmUserFromRole [-UserName]  <SmString>  [-RoleName]  <String>  [-Domain]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
UserName
Specifies the user you want to remove from the RBAC role.
true
true (ByPropertyName)
RoleName
Specifies the name of the role from which you want to remove the user.
true
Domain
Domain to which user belongs to. Workgroup users should skip this parameter.
false
Example 1: Deleting a role from a specific user
 Remove-SmUserFromRole  -UserName administrator -Domain mva -RoleName BackupAdmin
This example syntax removes the specified user from a role.
Are you sure you want to unassign the user from role?.
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
BackupAdmin
mva\administrator
Example 2: Deleting a role from a specific user without confirmation dialogue
 Remove-SmUserFromRole  -UserName administrator -Domain mva -RoleName BackupAdmin -Confirm:$false
BackupAdmin
mva\administrator
