SnapCenter 4.7 cmdlets
Start-SdVolumeCloneSplit
Starts your clone volume splitting operation.
Syntax
Start-SdVolumeCloneSplit [-Path]  <Object[]>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Path
Specifies the path to the clone volume you want to split.
true
true (ByPropertyName)
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
