Start-SdVolumeCloneSplit
Starts your clone volume splitting operation.
Syntax
Start-SdVolumeCloneSplit [-Path] <Object[]> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Path |
Specifies the path to the clone volume you want to split. |
true |
true (ByPropertyName) |
Session |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
