SnapCenter 4.9 cmdlets
Get-SmAuditSettings
Retrieves Audit configurations and Syslog configurations
Syntax
Get-SmAuditSettings
Detailed Description
Retrieves below configurations:Audit log related configuration -Maximum File SizeMaximum files to retainAudit Log file locationAudit Log Checksum file locationDisk Space Limit in Percentage, to raise alter after limit is reachedOption to Enable Audit Integrity Check ScheduleSyslog server related configuration -Option to Enable Syslog Server and update Syslog configurationSyslog Server HostSyslog Server PortSyslog ProtocolSyslog Format
Name Description Required? Pipeline Input Default Value
Example 1: Getting audit log and syslog server settings
 Get-SmAuditSettings
This example gets audit log and Syslog server settings.
MaxFileSize : 50
MaxSizeRollBackups : 10
UniversalTime : False
AuditLogDirectory : C:\Program Files\NetApp\SnapCenter WebApp\audit
AuditChecksumLogDirectory : C:\Program Files\NetApp\SnapCenter WebApp\auditChecksum
DiskSpaceLimitPercentage : 80
EnableAuditIntegrityCheckSchedule : False
EnableSyslogServer : True
SyslogServerHost : 10.229.39.107
SyslogServerPort : 1468
SyslogProtocol : TCP
SyslogFormat : Rfc5424
Example 2: Getting audit log settings and syslog server is disabled
 Get-SmAuditSettings
This example gets audit log settings and Syslog server is disabled.
MaxFileSize : 50
EnableSyslogServer : False
