Get-SmAuditSettings
Retrieves Audit configurations and Syslog configurations
Syntax
Get-SmAuditSettings
Detailed Description
Retrieves below configurations:Audit log related configuration -Maximum File SizeMaximum files to retainAudit Log file locationAudit Log Checksum file locationDisk Space Limit in Percentage, to raise alter after limit is reachedOption to Enable Audit Integrity Check ScheduleSyslog server related configuration -Option to Enable Syslog Server and update Syslog configurationSyslog Server HostSyslog Server PortSyslog ProtocolSyslog Format
| Name | Description | Required? | Pipeline Input | Default Value |
Example 1: Getting audit log and syslog server settings
Get-SmAuditSettings
This example gets audit log and Syslog server settings.
MaxFileSize : 50 MaxSizeRollBackups : 10 UniversalTime : False AuditLogDirectory : C:\Program Files\NetApp\SnapCenter WebApp\audit AuditChecksumLogDirectory : C:\Program Files\NetApp\SnapCenter WebApp\auditChecksum DiskSpaceLimitPercentage : 80 EnableAuditIntegrityCheckSchedule : False EnableSyslogServer : True SyslogServerHost : 10.229.39.107 SyslogServerPort : 1468 SyslogProtocol : TCP SyslogFormat : Rfc5424
Example 2: Getting audit log settings and syslog server is disabled
Get-SmAuditSettings
This example gets audit log settings and Syslog server is disabled.
MaxFileSize : 50 MaxSizeRollBackups : 10 UniversalTime : False AuditLogDirectory : C:\Program Files\NetApp\SnapCenter WebApp\audit AuditChecksumLogDirectory : C:\Program Files\NetApp\SnapCenter WebApp\auditChecksum DiskSpaceLimitPercentage : 80 EnableAuditIntegrityCheckSchedule : False EnableSyslogServer : False
