New-SmClone
Initiates a clone operation.
Syntax
New-SmClone [-DatasetName] <String> [-Policy] <String> [-AppPluginCode] <PluginCode> [-PDBName] <String> [-PDBCloneName] <String> [-CDBTargetSID] <String> [-PdbsToBeExcluded] <String> [-OpenPluggableDatabaseAfterClone] <Boolean> [-SkipTempTablespaceTempFileCreation] <> [-LogArchivedLocators] <Hashtable[]> [-Auth] <String> [-IsScheduled] <Boolean> [-ClusterName] <String> [-SMSBaseUrl] <String> [-IsNLBHost] <Boolean> [-ScheduleName] <String> [-CreateRemoteClone] <Boolean> [-Guid1] <String> [-Guid2] <String> [-BackupName] <String> [-Resources] <Hashtable[]> [-AppPluginCode] <PluginCode> [-CloneUidString] <String> [-CloneToInstance] <String> [-AutoAssignMountPoint] <> [-ArchivedLocators] <Hashtable[]> [-AssignMountPointUnderPath] <String> [-Suffix] <String> [-LogArchivedLocators] <Hashtable[]> [-LogRestoreType] <SmSqlLogRestoreType> [-LogCutOffDateTime] <DateTime> [-LogCount] <Int32> [-Auth] <String> [-IsScheduled] <Boolean> [-ClusterName] <String> [-SMSBaseUrl] <String> [-IsNLBHost] <Boolean> [-ScheduleName] <String> [-CloneLastBackup] <Int32> [-CreateRemoteClone] <Boolean> [-Guid1] <String> [-Guid2] <String> [-CloneName] <String> [-EnableEmail] <> [-PreScriptCommand] <String> [-PreScriptArguments] <String> [-PostScriptCommand] <String> [-PostScriptArguments] <String> [-ScriptTimeOut] <Int32> [-PreCloneScriptPath] <String> [-PostCloneScriptPath] <String> [-MountCommands] <String>
Detailed Description
Initiates a clone operation. You can initiate a clone job from either a clone dataset or an existing backup.
Name | Description | Required? | Pipeline Input | Default Value |
DatasetName |
Specifies the name of the clone dataset. |
true |
false |
Policy |
Specifies the clone policy you want to use. |
true |
false |
AppPluginCode |
Specifies the application plug-in type of the resource. Possible values are SMSQL and SCO. |
true |
false |
PDBName |
Source Oracle pluggable database name. |
false |
false |
PDBCloneName |
Pluggable Clone Oracle pluggable database name. |
false |
false |
CDBTargetSID |
Target container database SID. |
false |
false |
PdbsToBeExcluded |
List of Oracle pluggable databases to be excluded from newly cloned container database. |
false |
false |
OpenPluggableDatabaseAfterClone |
To open pluggable database after clone creation. |
false |
false |
SkipTempTablespaceTempFileCreation |
Skips creating a tempfile for the default temporary tablespace of the cloned database. |
false |
true (ByPropertyName) |
LogArchivedLocators |
Specifies the secondary storage system details for each unique primary storage system resource in the dataset. For example:-LogArchivedLocators @{Primary="my_vs1:my_vol_iscsi";Secondary="my_vs1:my_vol_iscsi_SECONDARY"} |
false |
false |
Auth |
This parameter is for internal use only. |
false |
false |
IsScheduled |
false |
false |
ClusterName |
false |
false |
SMSBaseUrl |
false |
false |
IsNLBHost |
false |
false |
ScheduleName |
false |
false |
CreateRemoteClone |
false |
Guid1 |
false |
false |
Guid2 |
false |
false |
OracleUntilCancel |
Specifies recovery will be performed using the latest available log backup. If archive log pruning is configured, the latest log backup having archive logs prior to pruning is selected for recovery. |
false |
OracleUntilScn |
Specifies the SCN of logs till which you want to recover the cloned Oracle Database. |
false |
OracleUntilTime |
Specifies the date and time till which you want to recover the cloned Oracle Database. You must specify the date and time in the 'MM-dd-yyyy HH:mm:ss' format. For example: '07/02/2018 06:12:15'. |
false |
ExternalArchiveLogMountPaths |
Specifies the alternate paths for archive logs to be used for recovery. Multiple alternate archive log paths can be specified in a comma separated list. |
false |
DataFilesMountPaths |
Specifies, in a hash table, the destination mount path, source directory path, and disk location type.For example: @{"DestinationMountPath" ="/mnt/db12c_data_STAND";"SourceDirectoryPath"=<br>"/mnt/db12c_data";"DiskLocationType"="MountPoint"} |
false |
DatabaseSID |
Specifies the Oracle system ID, which is used to uniquely identify a particular database. The maximum length of a clone SID is 8 characters.Example: -DatabaseSID STAND |
true |
DisableArchiveLogMode |
Specify if archive log mode to be disabled. |
false |
EnableOSAuthentication |
false |
OracleOsUserName |
Specifies the OS user name. For example: -OracleOsUserName oracle |
true |
OracleOsUserGroup |
Specifies the name of the Oracle OS user group. For example: oinstall |
true |
databaseLoginUserName |
Specifies the login name of the database user. |
false |
databaseLoginPassword |
Specifies the database user's login password. |
false |
OracleVersion |
Specifies the Oracle version.Example: -OracleVersion 12.1.0.2 |
false |
OracleHome |
Specifies the Oracle home directory.Example: -OracleHome /ora01/app/oracle/product/11.2.0/db_1 |
false |
ControlFileConfiguration |
Specifies the path for the control file in a hash table.For example: -ControlFileConfiguration @{"FilePath"="/mnt/db12c_data_STAND/STAND/control/control01.ctl"}, @{"FilePath"="/mnt/db12c_data_STAND/STAND/control/control02.ctl"} |
true |
RedoLogFileConfiguration |
Specifies the redo log file details in a hash table. The following parameters are required: FilePath, RedologNumber, TotalSize, BlockSize.The following is an example of using the RedoLogFileConfiguration parameter:-RedoLogFileConfiguration@{"FilePath"="/mnt/db12c_data_STAND/STAND/redolog/redo01.log";"RedologNumber"="1";"BlockSize"="512";"TotalSize"="50"}, @{"FilePath"="/mnt/db12c_data_STAND/STAND/redolog/redo02.log";"RedologNumber"="2";"BlockSize"="512";"TotalSize"="50"}, @{"FilePath" ="/mnt/db12c_data_STAND/STAND/redolog/redo03.log";"RedologNumber"="3";"BlockSize"="512";"TotalSize"="50"} |
true |
PostCloneSqlQueries |
Specifies any post-clone SQL queries. Multiple queries are separated by a semicolon ';'. |
false |
CustomParameters |
Specifies custom parameters in a hash table. At least one custom parameter is required.For example:-CustomParameters @{"Key" = "audit_file_dest";"Value"="/u01/app/oracle/admin/DB12C/adump_STAND"}, @{"Key"="log_archive_dest_1";"Value"="LOCATION=/u01/app/oracle/product/12.1.0.2/db_1/STAND"}You can use this parameter when you have a clone of a clone that fails with the error "ORA-00058: DB_BLOCK_SIZE must be 32768 to mount this database (not 8192)" to explicitly pass the custom parameter, for example:-CustomParameters @{"Key" = "DB_BLOCK_SIZE ";"Value"="value"} and substituting the correct block size. |
false |
RenamePDBConfiguration |
Renames the PDB configuration in a hash table using the following format:-RenamePDBConfiguration @{"CurrentName"="", "NewName"=""} |
false |
SkipRecovery |
Indicates that you want to skip the recovery operation of the cloned database. |
false |
false |
DatabasePort |
false |
ASMPort |
false |
DatabaseCredentialName |
false |
AsmCredentialName |
false |
SkipNIDCreation |
To skip new DBID creation for the cloned Oracle Database. |
false |
EmailBody |
false |
EmailFrom |
Specifies the sender's e-mail address. |
true |
EmailTo |
Specifies the receipient's e-mail address. |
true |
EmailSubject |
Specifies the subject of the e-mail. |
true |
EnableEmailAttachment |
false |
BackupName |
Specifies the name of the backup from which you want to clone.The following is an example of a SnapCenter Plug-in for Oracle Database backup name:-BackupName CDBPS_scomaddev_04-07-2016_06.14.38.8575_0 |
false |
false |
Resources |
Specifies the list of resources from which to clone. Use the Resources parameter when you are creating a clone from an existing backup.You must provide the resource information in a hashtable, and it must contain the resource name and type, as well as the host on which the resource is located. For example,@{"Host"="localhost";"Type"="SQL Database";"Names"="Instance\Database"}Valid Type value are SQL Database, Oracle Database, Windows Filesystem. For Oracle Database, the format is -Resources @{"Host"="host.example.com";"Oracle Database"="db"}. For Oracle Application Volume, the format is -Resources @{"Host"="host.example.com";"Application Volume"="appVol"}. |
true |
false |
CloneToInstance |
Specifies the SQL Server instance that you want to clone to. All databases in the clone dataset are cloned to this instance. For Oracle application volume resource, it specifies the host on which clone should be mounted. |
true |
AutoAssignMountPoint |
Specifies that the file system mount point is assigned automatically. |
false |
ArchivedLocators |
Specifies the secondary storage system details for each unique primary storage system resource in the dataset. For example:-ArchivedLocators @{Primary="my_vs1:my_vol_iscsi";Secondary="my_vs1:my_vol_iscsi_SECONDARY"} |
false |
AssignMountPointUnderPath |
Specifies that the file system mount point is created automatically under the specified mount path. |
false |
CloneUid |
Provide a target HANA clone UID. Use this parameter if you are creating a HANA clone on the same host as that of the source. You can use the -CloneUid parameter only with a HANA resource. |
false |
Suffix |
Provides a clone name suffix. All clones you create with one clone job are appended with the same suffix name. Use this parameter if you are creating a clone from an existing backup. You can use the -suffix parameter or the -clonename parameter, but not both. |
false |
LogRestoreType |
Specifies the recovery type for clones. Valid values are, the roll forward time, the number of logs to roll forward, or that you want to roll all logs forward. |
false |
LogCutOffDateTime |
When you specify the date and time in the LogRestoreType parameter, you can use LogCutOffDateTime parameter to indicate the cut off time. If the server and plug-in host are in different time zones, the input must be as per the plug-in host time zone. |
false |
LogCount |
When you specify a number of logs in LogRestoreType, use LogCount to specify the number of logs you want to roll forward. |
false |
CloneLastBackup |
false |
false |
CloneName |
Enables you to specify a new name for the cloned database or resource. You can use the -clonename parameter or the -suffix parameter, but not both. |
false |
EnableEmail |
Specifies whether to enable or disable e-mail. |
false |
false |
PreScriptCommand |
Specifies commands that are executed before the restore operation. |
false |
PreScriptArguments |
Specifies arguments to the prescript command. |
false |
PostScriptCommand |
Specifies the commands that are executed after the restore operation. |
false |
PostScriptArguments |
Specifies the arguments to the postscript command. |
false |
PreCloneScriptPath |
This is an Oracle Application Volume specific parameter. It specifies absolute path of the executable script to be run before Clone operation. The script should be located either at /var/opt/snapcenter/spl/scripts/ or any directory inside the path on the Oracle Plug-in host. |
false |
PostCloneScriptPath |
This is an Oracle Application Volume specific parameter. It specifies absolute path of the executable script to be run after Clone operation. The script should be located either at /var/opt/snapcenter/spl/scripts/ or any directory inside the path on the Oracle Plug-in host. |
false |
MountCommands |
This is an Oracle Application Volume specific parameter. It specifies commands to mount a file system to a the Clone Host. Mount command format is : mount <Source_SVM>:%<SOURCE_VOLUME_NAME>_Clone <mount_directory> To clone from secondary, the secondary volume name will be the SOURCE_VOLUME_NAME. Enter multiple mount commands separated by semi colon (;). |
false |
ScriptTimeOut |
Specifies the maximum time to wait for the script to complete before timing out. |
false |
InitiatorName |
Specifies the iSCSI IQN or FCP WWPN of the host on which the new clone will be created. |
false |
IgroupProtocol |
Specifies the Igroup protocol type (mixed, fcp, or iscsi) to be used for the new clone. |
false |
Example 1: Creating a clone from a dataset
New-SmClone -DatasetName payrollclone_dataset -Policy clonefromprimary_ondemand
This example syntax creates a new clone using the 'payrollclone_dataset' dataset and policy 'clonefromprimary_ondemand'.
Result : SMCoreContracts.SMResult TotalCount : 0 DisplayCount : 0 Context : Job : SMCoreContracts.SmJob Name: Clone life cycle of dataset 'payrollclone_dataset' with policy 'clonefromprimary_ondemand' Id : 85 StartTime : 8/5/2015 2:21:06 PM EndTime : IsCancellable : False IsRestartable : False IsCompleted : False IsVisible : False IsScheduled : False PercentageCompleted : 0 Description : Status : Queued Owner : Error : Priority: None Tasks : {} ParentJobID : 0 EventId : 0
Example 2: Creating a clone from backup with all logs
New-SmClone -BackupName payroll_dataset_vise-f3_08-05-2015_15.28.28.9774 -Resources @{"Host"="vise-f3.sddev.mycompany.com";"Type"="SQL Database";"Names"="vise-f3\SQLExpress\payroll"} -CloneToInstance vise-f3\sqlexpress -AutoAssignMountPoint -Suffix _clonefrombackup -LogRestoreType All -Policy clonefromprimary_ondemand
This example syntax creates a clone from the specified backup with all logs.
Result : SMCoreContracts.SMResult TotalCount : 0 DisplayCount : 0 Context : Job : SMCoreContracts.SmJob Clones : {}
Example 3: Creating a clone from backup with the specified number of logs
New-SmClone -BackupName payroll_dataset_vise-f3_08-05-2015_15.28.28.9774 -Resources @{" Host"="vise-f3.sddev.mycompany.com";"Type"="SQL Database";"Names"="vise-f3\SQLExpress\payroll"} -CloneToInstance vise-f 3\sqlexpress -AutoAssignMountPoint -Suffix _clonefrombackup1 -LogRestoreType ByTransactionLogs -LogCount 2 -Policy clone fromprimary_ondemand
This example syntax creates a clone from backup with the specified number of logs.
Example 4: Creating a clone from backup with no logs
New-SmClone -BackupName payroll_dataset_vise-f3_08-05-2015_15.28.28.9774 -Resources @{ Host"="vise-f3.sddev.mycompany.com";"Type"="SQL Database";"Names"="vise-f3\SQLExpress\payroll"} -CloneToInstance vise- 3\sqlexpress -AutoAssignMountPoint -Suffix _clonefrombackup1 -LogRestoreType None -Policy clonefromprimary_ondemand
This example syntax creates a clone from the specified backup with no logs.
Example 5: Creating a clone to Microsoft SQL Server instance
New-SmClone -BackupName "BackupDS1_NY-VM-SC-SQL_12-08-2015_09.00.24.8367" -Resources @{"host"="ny-vm-sc-sql";"Type"="SQL Database";"Names"="ny-vm-sc-sql\AdventureWorks2012_data"} -AppPluginCode SMSQL -CloneToInstance "ny-vm-sc-sql" -Suffix _CLPOSH -AutoAssignMountPoint -AssignMountPointUnderPath "C:\SCMounts"
This example syntax creates a clone to the specified Microsoft SQL Server instance.
Example 6: Creating an on demand clone of multiples resources of custom plugin DB2 on alternate host from primary Storage
New-SmClone -BackupName Verify_Clone_frombackup_Multiple_vols_with_multiple_resources_Alternate_Host_sccorelinux61_08-21-2016_19.04.14.6011 -Resources @(@{"Host"="sccorelinux61.sccore.test.com";"Uid"="Inst1\DB1"},@{"Host"="sccorelinux61.sccore.test.com";"Uid"="Inst21\DB2"}) -CloneToInstance sccore146.sccore.test.com -Suffix '_clone' -AutoAssignMountPoint -AppPluginCode 'DB2' -initiatorname 'iqn.1994-05.com.redhat:a24a75da948e' -igroupprotocol 'mixed'
This example syntax creates a clone of 2 resources, hosted on Storage type LUN, and creates a new clone on an alternate host, which takes initiatorName of new host and protocoltype to be used
Result : SMCoreContracts.SMResult TotalCount : 0 DisplayCount : 0 Context : Job : SMCoreContracts.SmJob Clones : {} Name: Clone from backup 'Verify_Clone_frombackup_Multiple_vols_with_multiple_resources_Alternate_Host_sccorelinux61_08-21-2016_19.04.14.6011' Id : 1043 StartTime : 8/21/2016 7:05:11 PM EndTime : IsCancellable : False IsRestartable : False IsCompleted : False IsVisible : True IsScheduled : False PercentageCompleted : 0 Description : Status : Queued Owner : Error : Priority: None Tasks : {} ParentJobID : 0 EventId : 0 PluginCode : NONE PluginName :
Example 7: Creating an on demand clone from Secondary Storage for custom plugin resource
New-SmClone -BackupName Verify_clone_secondary_SM_on_Qtree_unix_sccorelinux61_08-21-2016_16.57.18.8490 -Resources @{"Host"="sccorelinux61.sccore.test.com";"Uid"="QTREESM1"} -CloneToInstance sccorelinux61.sccore.test.com -Suffix '_QtreeClone4' -preclonecreatecommands 'mkdir /qtreeVol6_clone' -ArchivedLocators ( @{Primary="vserver_scauto_secondary:qtree_vol6_sccorelinux61_sccore_test_com";Secondary="vserver_scauto_primary:qtree_vol6SM_sccorelinux61_sccore_test_com"}) -AutoAssignMountPoint -AppPluginCode 'DB2' -mountcommand 'mount vserver_scauto_primary:%qtree_vol6_sccorelinux61_sccore_test_com/qtreeVol6_Clone /qtreeVol6_clone'
Clone QTree to same host from Secondary Storage using mount command.
At run-time, %qtree_vol6_sccorelinux61_sccore_test_com (source volume name) will resolve to new cloned volume name and new clone exported QTree will be mounted on folder "/qtreeVol6_clone
Example 8: Creating a clone of an ASM database
New-SmClone -BackupName "RG_084825_rhel68_asmsan_03-04-2017_08.49.52.1104_0" -AppPluginCode SCO -DatabaseSID clone -Resources @{"Host"="10.228.9.250";"Oracle Database"="sandb"} -AutoAssignMountPoint -CloneToInstance 10.228.9.250 -ControlFileConfiguration @{"FilePath"="/home/oracle/control01.ctl"} -RedoLogFileConfiguration @{"FilePath"="/home/oracle/redo03.log";"RedologNumber"="3";"TotalSize"="50";"BlockSize"="512"},@{"FilePath"="/home/oracle/redo02.log";"RedologNumber"="2";"TotalSize"="50";"BlockSize"="512"},@{"FilePath"="/home/oracle/redo01.log";"RedologNumber"="1";"TotalSize"="50";"BlockSize"="512"} -CustomParameters @{"Key" = "audit_file_dest";"Value"="/var/test"}
This example syntax creates a clone of an Automatic Storage Management (ASM) database.
Example 9: Creating a clone using a Windows file system resource
New-SmClone -CloneLastBackup 0 -Resources @{"Host"="localhost";"Type"="Windows Filesystem";"Names"="F:\"} -AppPluginCode SCW -AssignMountPointUnderPath C:\scmnpt\ -CloneToHost localhost
Example 10: Creating a remote clone
New-SmClone -BackupName SQL-Prod_mydb_SQL_Prod_10-23-2017_15.56.12.1837 -AppPluginCode SMSQL -Suffix _clone2 -Resources (@{"Host"="SQL-PROD";"Type"="SQL Database";"Names"="SQL-PRD\mydb"}) -CloneToInstance SQL-PRD -ArchivedLocators (@{Primary="svm1:sql_data";Secondary="svm1-dr:sql_data_vault"},@{Primary="svm1:sql_log";Secondary="svm1-dr:sql_log_vault"}) -AutoAssignMountPoint
This example syntax creates a clone from secondary storage with the following details: Primary data volume path: svm1:sql_data Secondary data volume path: svm1-dr:sql_data_vault Primary log volume path: svm1:sql_log Secondary log volume path: svm1-dr:sql_log_vault The "ArchivedLocators" attribute is populated as a hash table with Primary and Secondary values for each volume that hosts the SQL database you want to clone.
Example 11: Creating an on demand clone for hana database from primary backup and using NFSExportIPs to export the cloned volumes
New-SmClone -BackupName cn2_sccore_test_com_hana_NonDataVolume_C21_CN_cn2_06-21-2018_03.21.14.6261 -Resources @{"Host"="cn2";"UID"="NonDataVolume\C21\CN"} -AppPluginCode hana -CloneToInstance rhel182 -nfsexportips "RHEL182,10.232.206.116,sccorelinux61.sccore.test.com" -mountcommand "mount 10.232.206.5:%cn_p2_Clone /cn_vol_test"
Clone from primary storage using NFS Export IP field to specify the comma separated host name or IP address on which the cloned volumes are exported
Example 12: Creating a HANA Clone on same centralized host with mount command and NFS Export IPs
New-SmClone -BackupName "mva-s63_gdl_englab_com_hana_MDC_H14_mva-s63_03-22-2021_05.43.49.8438" -Resources @{"Host"="schana01.gdl.englab.netapp.com";"Uid"="MDC\R70"} -CloneToInstance "mva-s63.gdl.englab.com" -AppPluginCode HANA -CloneUid "MDC\H70" -nfsexportips "10.232.206.116,mva-s63.gdl.englab.com" -mountcommand "mount 10.232.206.5:%cn_p2_Clone /cn_vol_test"
HANA clone will be created using the same centralized host. In case of the same host, use -CloneUid paramter to specify the target clone UID.
Example 13: Creating an on demand clone for hana database from secondary backup and using NFSExportIPs to export the cloned volumes
New-SmClone -BackupName cn2_sccore_test_com_hana_NonDataVolume_C21_CN_cn2_06-21-2018_03.21.14.6261 -Resources @{"Host"="cn2";"UID"="NonDataVolume\C21\CN"} -AppPluginCode hana -CloneToInstance rhel182 -ArchivedLocators @{"primary"="vs_test1:cn_p2";"secondary"="vs_test1:cn_p2_vault1"} -nfsexportips "RHEL182,10.232.206.116,sccorelinux61.sccore.test.com" -mountcommand "mount 10.232.206.5:%cn_p2_Clone /cn_vol_test"
Clone from secondary storage backup using NFS Export IP field to specify the comma separated host name or IP address on which the cloned volumes are exported
Example 14: Creating an Oracle database clone from secondary using LogArchivedLocators
New-SmClone -OracleOsUserName oracle -OracleOsUserGroup oinstall -BackupName "auto-nfs_gdl_englab_netapp_com_nasdb_05-02-2018_08.39.11.5184_0" -AppPluginCode SCO -DatabaseSID Clon32 -Resources @{"Host"="auto-nfs.gdl.englab.netapp.com";"Oracle Database"="nasdb"} -AutoAssignMountPoint -CloneToInstance auto-nfs.gdl.englab.netapp.com -ControlFileConfiguration @{"FilePath"="/mnt/Data_Clon32/Clon32/control/control01.ctl"} -RedoLogFileConfiguration @{"FilePath"="/mnt/Data_Clon32/Clon32/redolog/redo01.log";"RedologNumber"="3";"TotalSize"="50";"BlockSize"="512"},@{"FilePath"="/MntPt_StaDB/Data_Clon32/Clon32/redolog/redo02.log";"RedologNumber"="2";"TotalSize"="50";"BlockSize"="512"},@{"FilePath"="/MntPt_StaDB/Data_Clon32/Clon32/redolog/redo03.log";"RedologNumber"="1";"TotalSize"="50";"BlockSize"="512"} -CustomParameters @{"Key" = "audit_file_dest";"Value"="/var/test"} -archivedlocators @{Primary="10.225.118.251:auto_nfs_data";Secondary="ongqathree_man:ongqaone_man_auto_nfs_data_vault"} -logarchivedlocators @{Primary="10.225.118.251:auto_nfs_log";Secondary="ongqathree_man:ongqaone_man_auto_nfs_log_vault"}
This example uses the -LogArchivedLocators to create an Oracle database clone from secondary storage.
Example 15: Creating an SQL clone using the clonename parameter to specify a new clone name
New-SmClone -BackupName SCNEW3_INSTANCE1_SCNEW3_MDML2_SCNEW3_02-28-2018_02.27.53 .7034 -Resources @{"Host"="SCNEW3";"Type"="SQL Database";"Names"="SCNEW3\INSTANCE1\SCNEW3_MDML2"} -CloneToInstance SCNE W3\INSTANCE1 -clonename '_Clone_035231' -LogRestoreType 'None' -AutoAssignMountPoint -AppPluginCode 'SCSQL'
This example creates a new clone _Clone_035231 using the -clonename parameter.
Example 16: Creating an ASM Oracle database clone using the backupname parameter
New-SmClone -OracleOsUserName oracle -OracleOsUserGroup oinstall -BackupName "scodev-us1_gdl_englab_netapp_com_asmud2_scodev-us1_04-13-2020_08.15.50.6683_0" -AppPluginCode SCO -DatabaseSID abc3 -Resources @{"Host"="scodev-us1.gdl.englab.netapp.com";"Oracle Database"="asmud2"} -AutoAssignMountPoint -CloneToInstance scodev-us1.gdl.englab.netapp.com -DataFilesMountPaths @{"DestinationMountPath"="SC_2443056968_abc3";"DiskLocationType"="Asm_DiskGroup";"SourceDirectoryPath"="DATAUDEV2"} -ControlFileConfiguration @{"FilePath"="+SC_2443056968_abc3/abc3/control/control01.ctl"} -RedoLogFileConfiguration @{"FilePath"="+SC_2443056968_abc3/abc3/redolog/redo03.log";"RedologNumber"="3";"TotalSize"="50";"BlockSize"="512"},@{"FilePath"="+SC_2443056968_abc3/abc3/redolog/redo02.log";"RedologNumber"="2";"TotalSize"="50";"BlockSize"="512"},@{"FilePath"="+SC_2443056968_abc3/abc3/redolog/redo01.log";"RedologNumber"="1";"TotalSize"="50";"BlockSize"="512"} -CustomParameters @{"Key" = "audit_file_dest";"Value"="/ora01/app/oracle_software/oracle_base/admin/abc3/adump"};
This example creates a new ASM Oracle database clone abc3 using the -BackupName parameter.
Example 17: Creating an Oracle PDB clone
New-SmClone -OracleOsUserName oracle -OracleOsUserGroup oinstall -BackupName "R706261C8F1V1_ZCDB1_R706261C8F1V1_08-03-2020_03.36.23.5540_0" -AppPluginCode SCO -PDBName PDB3 -PDBCloneName SCJOBID -CDBTargetSID ZCDB1 -OpenPluggableDatabaseAfterClone -Resources @{"Host"="scodev-us1.gdl.englab.netapp.com";"Oracle Database"="asmud2"} -AutoAssignMountPoint -CloneToInstance scodev-us1.gdl.englab.netapp.com -DataFilesMountPaths @{"DestinationMountPath"="SC_2443056968_abc3";"DiskLocationType"="Asm_DiskGroup";"SourceDirectoryPath"="DATAUDEV2"} -ControlFileConfiguration @{"FilePath"="+SC_2443056968_abc3/abc3/control/control01.ctl"} -RedoLogFileConfiguration @{"FilePath"="+SC_2443056968_abc3/abc3/redolog/redo03.log";"RedologNumber"="3";"TotalSize"="50";"BlockSize"="512"},@{"FilePath"="+SC_2443056968_abc3/abc3/redolog/redo02.log";"RedologNumber"="2";"TotalSize"="50";"BlockSize"="512"},@{"FilePath"="+SC_2443056968_abc3/abc3/redolog/redo01.log";"RedologNumber"="1";"TotalSize"="50";"BlockSize"="512"} -CustomParameters @{"Key" = "audit_file_dest";"Value"="/ora01/app/oracle_software/oracle_base/admin/abc3/adump"};
This example creates an Oracle PDB clone.
Example 18: Cloning an Oracle Application Volume from backup
New-SmClone -AppPluginCode SCO -BackupName "R8092776CF4V1_HNK2_com_appVol1_R8092776CF4V1_11-06-2021_03.04.13.5289" -Resources @{"Host"="R8092776CF4V1.HNK2.com";"Application Volume"="appVol1"} -CloneName testExampleClone -CloneToInstance R8092776CF4V1.HNK2.com -PreCloneScriptPath "/var/opt/snapcenter/spl/scripts/preClone.sh" -MountCommands "mount Test_SVM:%vol_test1_Clone /mnt/test" -PostCloneScriptPath "/var/opt/snapcenter/spl/scripts/postClone.sh"
This example clones an Oracle Application Volume from backup.
Example 19: Cloning an Oracle Application Volume from secondary storage backup
New-SmClone -AppPluginCode SCO -BackupName "R8092776CF4V1_HNK2_com_appVol1_R8092776CF4V1_11-06-2021_03.04.13.5289" -Resources @{"Host"="R8092776CF4V1.HNK2.com";"Application Volume"="appVol1"} -CloneName testExampleClone -CloneToInstance R8092776CF4V1.HNK2.com -ArchivedLocators @{"primary"="Source_SVM:vol_source";"secondary"="Dest_SVM:vol_source_dest"}
This example clones an Oracle Application Volume from secondary storage backup.
