Remove-SmResource
Removes a custom plug-in resource or an Oracle plug-in application volume resource.
Syntax
Remove-SmResource [-HostName] <String> [-PluginCode] <PluginCode>
Detailed Description
Enables you to delete a custom plug-in resource or an Oracle plug-in application volume resource from SnapCenter. This deletes only the SnapCenter object, not the actual application object.If the resource is protected, then the resource is only soft-deleted and is available for recall Undo-Resource cmdlet; otherwise, the resource is permanently deleted from SnapCenter.
Name | Description | Required? | Pipeline Input | Default Value |
HostName |
Specifies the name of host from which you want to remove the resource. |
true |
true (ByPropertyName) |
PluginCode |
Specifies the name of the plug-in associated with the resource you are removing. Possible inputs include HANA or any SCC Custom Plug-in name or SCO. |
true |
ResourceType |
The type of application object.For example, instance, database, or a SAP HANA SingleContainer or MultipleContainers. This parameter is not applicable for Oracle application volume resource. |
true |
ResourceName |
Specifies the name of the resource which you want to remove. |
true |
SID |
This is a SAP HANA database specific parameter. A SAP HANA system is identified by aunique 3 letter system ID (SID). For example, ABC. |
true |
TenantDatabaseName |
This is a SAP HANA database specific parameter. It is the name of the tenant database for SAP HANA Multitenant Database. |
false |
Remove a custom plugin resource
Remove-SmResource -HostName 'sccorelinux188.sccore.test.com' -PluginCode 'DB2' -Instance INST -ResourceType Database -ResourceName Db1
Remove a resource of type Database of custom plug-in type DB2
A resource will be soft deleted (marked as deleted) if the resource being deleted contains backup or is protected.
Successfully removed Inventory sccorelinux188.sccore.test.com:DB2:INST1\Db1
Remove a custom plugin resource without confirmation dialogue
Remove-SmResource -HostName 'sccorelinux188.sccore.test.com' -PluginCode 'DB2' -Instance INST -ResourceType Database -ResourceName Db1 -Confirm:$false
Remove-SmResource
Are you sure you want to remove the resource?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):
Remove SAP HANA Multitenant Database Container
Remove-SmResource -HostName 'scspr0204312001.gdl.englab.netapp.com' -PluginCode 'hana' -ResourceType MultipleContainers -SID NBC -TenantDatabaseName ttt
Remove Multitenant Database Container of SnapCenter Plug-in for SAP HANA. A resource will be soft deleted (marked as deleted) if the resource being deleted contains backup or is protected.
Remove-SmResource
Successfully removed Inventory scspr0204312001.gdl.englab.netapp.com:hana:NBC\ttt
Remove SingleContainer SAP HANA Database
Remove-SmResource -HostName 'scspr0204312001.gdl.englab.netapp.com' -PluginCode 'hana' -ResourceType SingleContainer -SID H14
Remove SingleContainer database of SnapCenter Plug-in for SAP HANA.
Remove-SmResource
Successfully removed Inventory scspr0204312001.gdl.englab.netapp.com:hana:H14
Removes an Oracle Application Volume resource
Remove-SmResource -HostName 'R8092776CF4V1.HNK2.com' -PluginCode 'SCO' -ResourceName 'appVol'
Removes an Oracle application volume resource.
Remove-SmResource
Are you sure you want to remove the resource : 'appVol' ?
Successfully removed resource R8092776CF4V1.HNK2.com:SCO:appVol
