SnapCenter 5.0 cmdlets
Remove-SmResource
Removes a custom plug-in resource or an Oracle plug-in application volume resource.
Syntax
Remove-SmResource [-HostName]  <String>  [-PluginCode]  <PluginCode>
Detailed Description
Enables you to delete a custom plug-in resource or an Oracle plug-in application volume resource from SnapCenter. This deletes only the SnapCenter object, not the actual application object.If the resource is protected, then the resource is only soft-deleted and is available for recall Undo-Resource cmdlet; otherwise, the resource is permanently deleted from SnapCenter.
Name Description Required? Pipeline Input Default Value
HostName
Specifies the name of host from which you want to remove the resource.
true
true (ByPropertyName)
PluginCode
Specifies the name of the plug-in associated with the resource you are removing. Possible inputs include HANA or any SCC Custom Plug-in name or SCO.
true
ResourceType
The type of application object.For example, instance, database, or a SAP HANA SingleContainer or MultipleContainers. This parameter is not applicable for Oracle application volume resource.
true
ResourceName
Specifies the name of the resource which you want to remove.
true
SID
This is a SAP HANA database specific parameter. A SAP HANA system is identified by aunique 3 letter system ID (SID). For example, ABC.
true
TenantDatabaseName
This is a SAP HANA database specific parameter. It is the name of the tenant database for SAP HANA Multitenant Database.
false
Remove a custom plugin resource
 Remove-SmResource -HostName 'sccorelinux188.sccore.test.com' -PluginCode 'DB2' -Instance INST -ResourceType Database -ResourceName Db1
Remove a resource of type Database of custom plug-in type DB2
A resource will be soft deleted (marked as deleted) if the resource being deleted contains backup or is protected.
Successfully removed Inventory sccorelinux188.sccore.test.com:DB2:INST1\Db1
Remove a custom plugin resource without confirmation dialogue
 Remove-SmResource -HostName 'sccorelinux188.sccore.test.com' -PluginCode 'DB2' -Instance INST -ResourceType Database -ResourceName Db1 -Confirm:$false
Remove-SmResource
Are you sure you want to remove the resource?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):
Remove SAP HANA Multitenant Database Container
 Remove-SmResource -HostName 'scspr0204312001.gdl.englab.netapp.com' -PluginCode 'hana' -ResourceType MultipleContainers -SID NBC -TenantDatabaseName ttt
Remove Multitenant Database Container of SnapCenter Plug-in for SAP HANA. A resource will be soft deleted (marked as deleted) if the resource being deleted contains backup or is protected.
Remove-SmResource
Successfully removed Inventory scspr0204312001.gdl.englab.netapp.com:hana:NBC\ttt
Remove SingleContainer SAP HANA Database
 Remove-SmResource -HostName 'scspr0204312001.gdl.englab.netapp.com' -PluginCode 'hana' -ResourceType SingleContainer -SID H14
Remove SingleContainer database of SnapCenter Plug-in for SAP HANA.
Remove-SmResource
Successfully removed Inventory scspr0204312001.gdl.englab.netapp.com:hana:H14
Removes an Oracle Application Volume resource
 Remove-SmResource -HostName 'R8092776CF4V1.HNK2.com' -PluginCode 'SCO' -ResourceName 'appVol'
Removes an Oracle application volume resource.
Remove-SmResource
Are you sure you want to remove the resource : 'appVol' ?
Successfully removed resource R8092776CF4V1.HNK2.com:SCO:appVol
