SnapCenter 4.8 cmdlets
Add-SmPolicy
Creates a new backup policy.
Syntax
Add-SmPolicy [-PolicyName]  <String>  [-PolicyType]  <SmPolicyType>  [-PluginPolicyType]  <PluginCode>  [-Description]  <String>
Detailed Description
Creates a new backup policy. A policy is a set of rules governing backup jobs. A Policy includes backup type, verification schedules, and pre-script and post-script arguments.
Name Description Required? Pipeline Input Default Value
PolicyName
Specifies the name of the policy you are adding.
true
true (ByPropertyName)
PolicyType
Specifies the policy type. Valid value is Backup.
true
PluginPolicyType
Specifies the type of plug-in. You need to specify a plug-in type because policies are settings that are specific to one type of plug-in. For example, if you want to create a policy for resources contained in a SnapCenter Plug-in for Microsoft SQL Server dataset, the plug-in types are SCSQL and SCO.Available plug-in policy types include SCSQL, SCO, SCU, HANA, SCW, SCE.
true
Provides an optional description of the policy you are adding.
false
UtmType
Type of up to the minute (UTM) retention settings to apply to log backups. Possible values are days and count.
false
UtmCount
Up to the minute (UTM) retention by count.
false
UtmDays
Up to the minute (UTM) retention by days.
false
SqlBackupType
SQL backup type. Possible values are LogBackup, FullBackup and FullBackupAndLogBackup.
true
DatabasesPerGroup
Maximum number of databases in a group. This is applicable only for full backup.
false
CopyOnlyBackup
Determines whether the full backup is a copy only backup.
false
AGBackupType
Availability Group backup type. Possible values are UsePreferredBackupReplica and UseSpecifiedBackupReplica.
false
AGBackupReplicaType
Availability Group backup replica type. Possible values are Primary, Secondary and All.
false
AGBackupPriorityMinimum
Availability Group backup minimum priority.
false
AGBackupPriorityMaximum
Availability Group backup maximum priority.
false
CreateLogFolderSnapshot
Creates a Log folder Snapshot copy.
false
EnableLogFolderSnapshotRetention
Enables log folder Snapshot copy retention.
false
DeleteLogFolderSnapshotInExcess
false
DeleteLogFolderSnapshotOlderThan
Deletes log folder Snapshot copies that are older than the specified number of days.
false
VerifyLogBackup
Enables log backup verification after backup.
false
DBCC_NOINDEX
DBCC options NOINDEX.
false
false
DBCC_ALL_ERRORMSGS
DBCC options ALL_ERRORMSGS.
false
DBCC_NO_INFOMSGS
DBCC options NO_INFOMSGS.
false
DBCC_TABLOCK
DBCC options TABLOCK.
false
DBCC_PHYSICALONLY
DBCC options PHYSICALONLY.
false
UpdateSnapMirrorAfterbackup
Update SnapMirror copy after backup. This option is not applicable for SAP HANA policy of File-Based Backup type.
false
UpdateSnapVaultAfterbackup
Update SnapVault copy after backup. This option is not applicable for SAP HANA policy of File-Based Backup type.
false
MirrorVaultUpdateRetryCount
Number of retries to ensure SnapMirror or SnapVault update is triggered.
false
SnapVaultLabel
Label for SnapVault.
false
AllowSavedStateBackup
Allow saved state backup.
false
DeleteBackupInExcess
Delete backup in excess of specified days, it is applicable to only SnapCenter Plug-in for VMware vSphere, if it is used with other plug-ins it will be ignored.
false
DeleteBackupOlderThan
Delete backups older than specified days, it is applicable to only SnapCenter Plug-in for VMware vSphere, if it is used with other plug-ins it will be ignored.
false
PreScriptCommandVerification
Specifies the path of the prescript that should be run before the backup operation.
false
PreScriptArgumentsVerification
Specifies the prescript arguments.
false
PostScriptCommandVerification
Specifies the path of the postscript that should be run after the backup operation.
false
PostScriptArgumentsVerification
false
ScriptTimeOutVerification
false
ScheduleType
The schedule type. Possible values are None, Hourly, Weekly, Daily, and Monthly.
false
RetentionSettings
Specifies in a hashtable the retention settings for the policy.
false
PreScriptCommand
Prescript file UNC path with proper privileges for scripts accessibility, (‘\\\\server\\share\path\\file’ for Universal Naming Convention (UNC) names).
false
PreScriptArguments
false
PostScriptCommand
Postscript file UNC path with proper privileges for scripts accessibility, (‘\\\\server\\share\path\\file’ for Universal Naming Convention (UNC) names).
false
PostScriptArguments
Specifies postscript arguments.
false
ScriptTimeOut
Specifies script timeout value in seconds.
false
VerificationScheduleType
false
DeleteCloneOnScheduleExpiry
Removes a clone during the last run of a scheduled job.If this parameter is not set, then the last run of a schedule also runs a clone life cycle and creates a cloned database.This parameter does not apply to jobs that are not scheduled or to one time job schedules.
false
BackupPolicyName
Specifies the backup policy name.
true
CloneType
Specifies the clone type. Possible values are Primary and Secondary.
false
VerifyOnSecondary
Specifies whether to verify on secondary or not.
false
false
NumOfBackups
Number of backups to be verified.
false
false
PluginParams
false
DominoChangeInfoPath
false
DominoDatabaseType
false
DominoIniPath
false
DominoRestoreFilePath
false
DominoRestoreTime
false
Lotus
false
NotesExecDirectory
false
DominoDisableReplication
false
DominoIgnoreCorruptedDB
false
DBMCliCmd
false
HandleLogWriter
false
MaxDBBGServerPrefix
false
MaxDBUpdateHistLog
false
SQLCliCmd
false
XUserEnable
false
DB2Cmd
false
SybaseISQLCmd
false
SybaseManifest
false
SybaseManifestDelete
false
SybaseManifestFormat
false
SybaseTranDump
false
SybaseTranDumpCompress
false
SybaseTranDumpFormat
false
BackupType
This is a SAP HANA database specific parameter. Specifies the type of SAP HANA backup. The possible values are FileBasedBackup and SnapshotBasedBackup.
true
OracleBackupType
Specifies the Oracle backup type. Backup types include Online, Offline mount, and Offline shutdown.
true
OracleBackupScope
This option is only valid when the backup type is Online. Backup scope values are Full, Data, and Log.
true
OracleSkipPDBSaveState
Enables you to skip PDB save state. This parameter is only available when you select Offline shutdown backup type. Values are True or False.
false
DeleteAllArchiveLogs
Prunes (deletes) all archive logs after Full or Log backups.
false
DeleteArchiveLogsOlderThan
Prunes (deletes) archive logs older than a specified number of days. This parameter supports the use decimals to enable you to specify a fraction of a day. For example, 2.5 represents 2 days and 12 hours, and 0.04 represents 1 hour.
false
DeleteArchiveLogFromAllDestination
This parameter enables pruning of archive logs on a specified destination. If the value is True, archive logs are pruned on all destinations. If the option is False, archive logs are pruned only on backed up destinations.
false
DeleteArchiveLogBackupInExcess
Deletes archive log backup in excess of the specified backup count.
false
DeleteAchiveLogBackupOlderThan
Deletes archive log backups that are older than the specified number of days. This parameter supports the use decimals to enable you to specify a fraction of a day. For example, 2.5 represents 2 days and 12 hours, and 0.04 represents 1 hour.
false
CatalogBackupWithOracleRMAN
Specifies that you want to catalog backup using Oracle Recovery Manager (RMAN).
false
ScwBackupType
The SnapCenter Plug-in for Windows backup type. Values are ApplicationConsistent, FilesystemConsistent and CrashConsistent.
true
SceBackupType
true
UtmCounts
false
BackupTruncatedTransactionLog
false
BackupActiveCopies
false
BackupCopiesOnServer
false
Example 1: Creating a new hourly policy with scheduler type as SQL
 Add-SmPolicy -PolicyName TESTPolicy - PluginPolicyType SCSQL -PolicyType Backup -SqlBackupType FullBackup -ScheduleType Hourly -Verbose –SchedulerType SQL
This example syntax creates a new hourly policy with the SQL scheduler type.
Example 2: Creating an Oracle policy that prunes all archive logs on all destinations, and deletes archive log backups in excess of 5
 Add-SmPolicy -PolicyName 1 -PolicyType Backup -PluginPolicyType SCO -OracleBackupType ONLINE -OracleBackupScope FULL -DeleteAllArchiveLogs $true -DeleteArchiveLogFromAllDestination $true -DeleteArchiveLogBackupInExcess 5
This example syntax creates an Oracle policy that prunes all archive logs on all destinations, and deletes archive log backups in excess of 5.
ApplySnapvaultUpdate: False
ApplyRetention  : False
RetentionCount  :
RetentionDays   :
ApplySnapMirrorUpdate   : False
SnapVaultLabel  :
MirrorVaultUpdateRetryCount : 3
AppPolicies : {}
Description :
PreScriptPath   :
PreScriptArguments  :
PostScriptPath  :
PostScriptArguments :
ScriptTimeOut   : 60000
DateModified: 10/5/2015 2:17:57 PM
DateCreated : 10/5/2015 2:17:57 PM
Schedule: SMCoreContracts.SmSchedule
PolicyType  : Backup
PluginPolicyType: SCO
Type:
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
Hosts   : {}
SmOracleBackupType : ONLINE
SmOracleBackupScope: FULL
SmOraclePDBSaveState   : True
PruneArchiveLog: True
PruneArchiveLogType: AllLogs
PruneArchiveLogOlderThanDays   :
PruneArchiveLogDestinationType : AllDestinations
DeleteArchiveLogBackup : True
ArchiveLogBackupRetentionType  : CountBase
DeleteArchiveLogBackupCounts   : 5
DeleteArchiveLogBackupDays :
Name   :
Type   :
Id :
Host   :
UserName   :
Passphrase :
Deleted: False
Auth   : SMCoreContracts.SmAuth
IsClone: False
CloneLevel : 0
Hosts  : {}
Example 3: Creating a policy for custom plugin DB2 with daily schedule type
 Add-SMPolicy -PolicyName 'DB2_DAILY_POLICY' -PolicyType 'Backup' -PluginPolicyType DB2-retentionsettings @{"BackupType"="DATA";"ScheduleType"="DAILY";"RetentionCount"='3'} -description 'DB2 daily schedule policy' -scheduletype 'DAILY'
This example syntax creates a daily scheduled policy for custom plug-in DB2 with retention count 3
ApplyRetention  : True
RetentionCount  : 3
RetentionDays   : 0
SnapVaultLabel  :
AppPolicies : {}
DateCreated : 8/22/2016 9:37:43 AM
DateModified: 8/22/2016 9:37:43 AM
Description : DB2 daily schedule policy
PluginPolicyType: DB2
PolicyType  : Backup
PostScriptPath  :
PreScriptPath   :
Schedules   : {}
ScriptTimeOut   : 60
Type:
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Hosts   : {}
TaskName  :
Hosts : {}
StartTime :
DaysoftheMonth:
MonthsofTheYear   :
DaysInterval  : 0
DaysOfTheWeek :
AllowDefaults : False
ReplaceJobIfExist : False
UserName  :
Password  :
SchedulerType : Daily
RepeatTask_Every_Hour :
IntervalDuration  :
EndTime   :
LocalScheduler:
AppType   :
AuthMode  :
SchedulerSQLInstance  : SMCoreContracts.SmObject
MonthlyFrequency  :
ScheduleID: 0
PolicyId   : 18
PluginName : DB2
PluginParams   : SMCoreContracts.SmKeyValueCollection
SmSCBackupType : DataBackup
Name   :
Type   :
Id :
Host   :
UserName   :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts  : {}
Example 4: Creating a new Windows backup policy
 Add-SmPolicy -PolicyName scw_policy -PolicyType Backup -PluginPolicyType SCW -ScwBackupType CrashConsistent
This example syntax creates a new Windows backup policy.
ApplySnapvaultUpdate : False
RetentionCount   :
RetentionDays:
ApplySnapMirrorUpdate: False
SnapVaultLabel   :
AppPolicies  : {}
Description  :
PreScriptPath:
PostScriptPath   :
ScriptTimeOut: 60
DateModified : 5/18/2016 6:36:24 PM
DateCreated  : 5/18/2016 6:36:24 PM
Schedule : SMCoreContracts.SmSchedule
PolicyType   : Backup
PluginPolicyType : SDW
Type :
Host :
UserName :
Passphrase   :
Deleted  : False
IsClone  : False
CloneLevel   : 0
Hosts: {}
ScwBackupType : CrashConsistent
Name  :
Type  :
Id:
Host  :
UserName  :
Passphrase:
Deleted   : False
IsClone   : False
CloneLevel: 0
Hosts : {}
Example 5: Creating a new backup policy for SnapCenter Plugin for SAP HANA backup of type FileBasedBackup
 Add-SmPolicy -PolicyName newpol123 -PolicyType Backup -PluginPolicyType hana -BackupType FileBasedBackup
This example syntax creates a new backup policy for SnapCenter Plug-in for SAP HANA with FileBasedBackup as the backup type.
MirrorVaultUpdateRetryCount : 0
RetentionCount  : 7
RetentionDays   : 0
SnapVaultLabel  :
AppPolicies : {}
DateCreated : 3/23/2017 10:14:31 PM
DateModified: 3/23/2017 10:14:31 PM
Description :
PluginPolicyType: hana
PolicyType  : Backup
PostScriptPath  :
PreScriptPath   :
Schedules   : {}
ScriptTimeOut   : 60
Type:
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Hosts   : {}
StorageName :
ResourceGroupNames  :
PolicyNames :
Key : 0
NsmObjectID : 0
Retention Settings
BackupType  : DATA
SchedulerType   : None
RetentionCount  : 7
RetentionDays   : 0
VerificationEnabled : False
NodeName:
PolicyId   : 39
PluginName : hana
SmSCBackupType : FileBasedBackup
Name   :
Type   :
Id :
Host   :
UserName   :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts  : {}
StorageName:
PolicyNames:
Key: 0
NsmObjectID: 0
Example 6: Creating a new backup policy for SnapCenter Plugin for SAP HANA backup of type SnapshotBasedBackup
 Add-SmPolicy -PolicyName hana_snapshotbased -PolicyType Backup -PluginPolicyType hana -BackupType SnapShotBasedBackup
This example syntax creates a new backup policy for SnapCenter Plug-in for SAP HANA with SnapshotBasedBackup as the backup type.
RetentionCount  : 7
RetentionDays   : 0
SnapVaultLabel  :
AppPolicies : {}
DateCreated : 3/23/2017 10:17:30 PM
DateModified: 3/23/2017 10:17:30 PM
Description :
PolicyType  : Backup
PostScriptPath  :
PreScriptPath   :
Schedules   : {}
ScriptTimeOut   : 60
Type:
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Hosts   : {}
StorageName :
PolicyNames :
Key : 0
NsmObjectID : 0
Retention Settings
BackupType  : DATA
RetentionCount  : 7
RetentionDays   : 0
NodeName:
PolicyId   : 41
PluginName : hana
Name   :
Type   :
Id :
Host   :
UserName   :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts  : {}
StorageName:
PolicyNames:
Key: 0
NsmObjectID: 0
Example 7: Adding a policy with a retention based on number of days
          retentionsettings @{"BackupType"="DATA";"ScheduleType"="DAILY";"RetentionDays"='3'} -
