Disconnect-SdStorage
Disconnects your storage system from your Windows disk or SMB share.
Syntax
Disconnect-SdStorage [-Path] <String> [-IgnoreVolumeMountPoint] <> [-Session] <String> [-Host] <String>
Detailed Description
Disconnects your Windows disk or SMB share from your storage system.
| Name | Description | Required? | Pipeline Input | Default Value |
Path |
Specifies your LUN path or mount point using the format: D:, D:\Mount |
true |
true (ByPropertyName) |
IgnoreVolumeMountPoint |
false |
Session |
Specifies the Session ID from Open-SmConnection |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
Example 1: Disconnecting a storage system from a Windows drive
PS C:\> Disconnect-SDStorage –Path K:
This example syntax disconnect the specified drive from a storage system.
Example 2: Disconnectinga storage system from a Windows mount point
PS C:\> Disconnect-SDStorage –Path K:\Mount
This example syntax disconnect the specified Mount Point from a storage system.
