SnapCenter 5.0 cmdlets
Disconnect-SdStorage
Disconnects your storage system from your Windows disk or SMB share.
Syntax
Disconnect-SdStorage [-Path]  <String>  [-IgnoreVolumeMountPoint]  <>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Disconnects your Windows disk or SMB share from your storage system.
Name Description Required? Pipeline Input Default Value
Path
Specifies your LUN path or mount point using the format: D:, D:\Mount
true
true (ByPropertyName)
false
Session
Specifies the Session ID from Open-SmConnection
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Disconnecting a storage system from a Windows drive
 PS C:\> Disconnect-SDStorage –Path K:
This example syntax disconnect the specified drive from a storage system.
Example 2: Disconnectinga storage system from a Windows mount point
 PS C:\> Disconnect-SDStorage –Path K:\Mount
This example syntax disconnect the specified Mount Point from a storage system.
