SnapCenter 4.8 cmdlets
Get-SdFCPInitiator
Lists FCP initiators.
Syntax
Get-SdFCPInitiator [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Session
Specifies the session ID from Open-SmConnection.
false
true (ByPropertyName)
Host
Specifies the name of the computer or host on which the SnapCenter Plug-in for Microsoft Windows service you want to perform the operation runs. The default is your local machine.
false
Example 1: Listing all FCP initiators
 PS C:\> Get-SdFCPInitiator
This example syntax displays all your FCP initiators.
