Get-SdFCPInitiator
Lists FCP initiators.
Syntax
Get-SdFCPInitiator [-Session] <String> [-Host] <String>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
Session |
Specifies the session ID from Open-SmConnection. |
false |
true (ByPropertyName) |
Host |
Specifies the name of the computer or host on which the SnapCenter Plug-in for Microsoft Windows service you want to perform the operation runs. The default is your local machine. |
false |
Example 1: Listing all FCP initiators
PS C:\> Get-SdFCPInitiator
This example syntax displays all your FCP initiators.
