Get-SmRole
Get information for one or more RBAC roles.
Syntax
Get-SmRole [-Name] <String>
Detailed Description
Get information about all the roles associated with SnapCenter. If you specify a specific role, you will return only information about the individual role.This information includes the role description, name.
Name | Description | Required? | Pipeline Input | Default Value |
Name |
Specifies the name of the role for which you want information. If you do not specify a role name, you will receive information for all available roles. |
false |
true (ByPropertyName) |
Example 1: Getting information about all roles
Get-SmRole
This example syntax retrieves the information about all SnapCenter roles.
Description : Overall administrator of SnapCenter system Name: SnapCenterAdmin Type: Administrator Id : 1 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Description : Backup and Clone Viewer Name: Backup and Clone Viewer Type: Backup and Clone Viewer Id : 7 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Description : App Backup and Clone Admin Name: App Backup and Clone Admin Type: App Backup and Clone Admin Id : 8 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Description : Infrastructure Admin Name: Infrastructure Admin Type: Infrastructure Admin Id : 9 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0
Example 2: Getting information about a specific role
Get-SmRole -Name "Infrastructure Admin"
This example syntax retrieves the information about the specified role.
