New-SmAlert
Create new alert.
Syntax
New-SmAlert [-Name] <String> [-Description] <String> [-Recommendation] <String> [-Severity] <SmAlertSeverity> [-Status] <SmAlertStatus> [-EntityType] <SmEntityType> [-EntityName] <String> [-JobId] <String> [-Source] <SmAlertSource>
Detailed Description
To create new alert, Valid connection is required. You should provide alert severity like Informational, Warning or Critical and EntityType can be All, SnapCenterServer, Host or StorageSystem. The Source parameter should be ConfigurationChecker or SnapCenterServer.
| Name | Description | Required? | Pipeline Input | Default Value |
Name |
true |
true (ByPropertyName) |
Description |
true |
Recommendation |
true |
Severity |
true |
Status |
false |
EntityType |
true |
EntityName |
false |
JobId |
true |
Source |
true |
Example 1: Create new alert
New-SmAlert -Name TestAlert -Description ForSnapCenter -Recommendation AnyRecom -Severity Informational -Status New -EntityType Host -EntityName WIN-SCServer.Domain1.com -JobId 162 -Source SnapCenterServer
This example syntax creates an alert.
Id : CreatedTime: 1/1/0001 12:00:00 AM ModifiedTime : 1/1/0001 12:00:00 AM Name : TestAlert Status : New Severity : Informational Entity : SMCoreContracts.ConfigCheck.SmEntity Description: ForSnapCenter Recommendation : AnyRecom JobId : 162 Source : SnapCenterServer IsRulePassed : False EntityType : Host EntityName : WIN-SCServer.Domain1.com EntityId : Username : Password : Port :
