SnapCenter cmdlets
New-SmAlert
Create new alert.
Syntax
New-SmAlert [-Name]  <String>  [-Description]  <String>  [-Recommendation]  <String>  [-Severity]  <SmAlertSeverity>  [-Status]  <SmAlertStatus>  [-EntityType]  <SmEntityType>  [-EntityName]  <String>  [-JobId]  <String>  [-Source]  <SmAlertSource>
Detailed Description
To create new alert, Valid connection is required. You should provide alert severity like Informational, Warning or Critical and EntityType can be All, SnapCenterServer, Host or StorageSystem. The Source parameter should be ConfigurationChecker or SnapCenterServer.
Name Description Required? Pipeline Input Default Value
Name
true
true (ByPropertyName)
true
Recommendation
true
Severity
true
Status
false
EntityType
true
EntityName
false
JobId
true
Source
true
Example 1: Create new alert
 New-SmAlert -Name TestAlert -Description ForSnapCenter -Recommendation AnyRecom -Severity Informational -Status New -EntityType Host -EntityName WIN-SCServer.Domain1.com -JobId 162 -Source SnapCenterServer
This example syntax creates an alert.
Id :
			CreatedTime: 1/1/0001 12:00:00 AM
			ModifiedTime   : 1/1/0001 12:00:00 AM
			Status : New
			Severity   : Informational
			Entity : SMCoreContracts.ConfigCheck.SmEntity
			Description: ForSnapCenter
			Recommendation : AnyRecom
			JobId  : 162
			Source : SnapCenterServer
			IsRulePassed   : False
			EntityType : Host
			EntityName : WIN-SCServer.Domain1.com
			EntityId   :
			Username   :
			Password   :
			Port   :
