Set-SmResourceCredentialName
Set the credential for the SQL instance registered with the SnapCenter Server.
Syntax
Set-SmResourceCredentialName [-ResourceAuths] <Hashtable[]>
Detailed Description
Set the credential for the SQL instance registered with the SnapCenter Server based on the credential information provided.
| Name | Description | Required? | Pipeline Input | Default Value |
ResourceAuths |
true |
true (ByPropertyName) |
- Example : Setting the credential for the SQL instance by RunAs ID. -
Set-SmResourceCredentialName -ResourceAuths @{"CredentialId"="3";"Names"="R708202074BV1\SQL2019";}
This example syntax sets the credential for the SQL instance registered with the SnapCenter Server based on the RunAs ID provided.
AppObject Auth
SMCoreContracts.SmObject SMCoreContracts.SmAuth
