SnapCenter cmdlets
Set-SmResourceCredentialName
Set the credential for the SQL instance registered with the SnapCenter Server.
Syntax
Set-SmResourceCredentialName [-ResourceAuths]  <Hashtable[]>
Detailed Description
Set the credential for the SQL instance registered with the SnapCenter Server based on the credential information provided.
Name Description Required? Pipeline Input Default Value
ResourceAuths
true
true (ByPropertyName)
- Example : Setting the credential for the SQL instance by RunAs ID. -
 Set-SmResourceCredentialName -ResourceAuths @{"CredentialId"="3";"Names"="R708202074BV1\SQL2019";}
This example syntax sets the credential for the SQL instance registered with the SnapCenter Server based on the RunAs ID provided.
AppObject Auth
SMCoreContracts.SmObject SMCoreContracts.SmAuth
