SnapCenter cmdlets
Set-SmSMTPServer
Specifies the SMTP server to use for sending data protection job reports to yourself or to others.
Syntax
Set-SmSMTPServer [-SMTPServerName]  <String>  [-EmailFrom]  <String>  [-EmailTo]  <String>  [-IsSendEmail]  <>  [-EmailSubject]  <String>
Detailed Description
Specifies the SMTP server to use for sending data protection job reports to yourself or to others. The settings are applied globally for any SnapCenter job for which you configure email notification.
Name Description Required? Pipeline Input Default Value
SMTPServerName
Specifies the name of the SMTP server.
true
true (ByPropertyName)
EmailFrom
Specifies the sender's email address. This parameter is required when you configure an SMTP server.
true
EmailTo
Specifies the recipient's email address. This parameter is required when you configure an SMTP server.
true
IsSendEmail
When specified, sends email to the SMTP server specified. This parameter is optional.
false
false
EmailSubject
Specifies the subject of the email. This parameter is optional.
false
false
Example 1
 Set-SmSMTPServer smtp.gdl.englab.netapp.com -EmailFrom zhimao@netapp.com -EmailTo zhimao@netapp.com -IsSendEmail -EmailSubject Hello
