Get-SdLunMap
Gets information about all the mapped LUNs and the igroups to which they are mapped.
Syntax
Get-SdLunMap [-StorageSystem] <String> [-LunPath] <String> [-Session] <String> [-Host] <String>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
StorageSystem |
Specifies the storage system on which the igroup, to which you mapped your LUNs, is located. |
true |
true (ByPropertyName) |
LunPath |
Specifies the path of the LUN on your storage system. |
false |
Session |
Specifies the session ID from Open-SmConnection. |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
