SnapCenter cmdlets
Remove-SmDomain
Unregister a registered domain.
Syntax
Remove-SmDomain [-Name]  <String>
Detailed Description
Remove a registered domain from SnapCenter server.
Name Description Required? Pipeline Input Default Value
Name
NETBIOS Name of the registered domain to be removed.
true
true (ByPropertyName)
Example 1: Unregister a registered domain from SnapCenter Server.
 Remove-SmDomain -Name dom-newad01
Remove-SmDomain
The domain "dom-newad01" will be unregistered from SnapCenter Server and the domain users will no longer be able to access the SnapCenter Server.
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
