Remove-SmDomain
Unregister a registered domain.
Syntax
Remove-SmDomain [-Name] <String>
Detailed Description
Remove a registered domain from SnapCenter server.
Name | Description | Required? | Pipeline Input | Default Value |
Name |
NETBIOS Name of the registered domain to be removed. |
true |
true (ByPropertyName) |
Example 1: Unregister a registered domain from SnapCenter Server.
Remove-SmDomain -Name dom-newad01
Remove-SmDomain
The domain "dom-newad01" will be unregistered from SnapCenter Server and the domain users will no longer be able to access the SnapCenter Server.
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
