SnapCenter cmdlets
Remove-SmJobs
Removes completed jobs.
Syntax
Remove-SmJobs [-JobId]  <Int32>  [-StartTime]  <DateTime>  [-EndTime]  <DateTime>  [-Auth]  <String>
Detailed Description
Removes completed jobs using either the job ID of a specific job or all jobs within a specified date and time.
Name Description Required? Pipeline Input Default Value
JobId
Specifies the ID of the job you want to remove.
false
false
StartTime
Specifies that jobs completed after the specified date and time should be removed.
false
false
EndTime
Specifies that jobs completed before the specified date and time should be removed.
false
false
Auth
false
false
Example 1: Removing a job using a specific job ID
 Remove-SmJobs -JobId 1002
This example syntax removes the job associated with the specified job ID.
Remove-SmJobs
Are you sure want to remove all the jobs(s) ?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Example 2: Removing jobs completed within specific start and end dates without a confirm dialogue
 Remove-SmJobs -StartTime 02/12/2015 -EndTime 07/02/2015 -Confirm:$false
This example syntax removes jobs completed between the specified beginning and end dates.
